Turn the key alternator light flashes and makes noise like a turn signal. Does not go out when I start the car.
I see 14v across the + and - on the battery with engine running and 12.3 or so with engine off.
Replaced VR with no change.
PO changed the electrical portion of the ignition switch because you could remove the key and the car would keep running. My wipers work and my horn does not.
I don’t think horn is related because I removed the batwing and the cable is not connected.
