Hi everybody, I'm trying to find an a/c Dpd condenser replacement, closest I can find is the 12"×14" the opening is 13"×16-3/8" If someone has use a certain size model Thanks Pedro
Shivers
Mar 8 2022, 02:57 PM
If it is all metal, someone like this may be able to rebuild it.
Parallel flow condensers are much more efficient than the old style. Slightly smaller isn't going to be a detriment except for needing to fill the gaps.
pedrok
Mar 9 2022, 08:06 AM
Thank you guys Chris yes will fill those gaps, did a search and couldn't find an exact size match Pedro
904svo
Mar 9 2022, 08:37 AM
QUOTE(pedrok @ Mar 9 2022, 06:06 AM)
TRY George at Auto Atlantic he has spares.
JamesM
Mar 9 2022, 02:09 PM
QUOTE(Chris914n6 @ Mar 9 2022, 01:21 AM)
Problem with a direct replacement with a parallel flow condenser is that you don't want to mount a parallel flow condenser horizontally.
Would be bad.
