I personally think impacts are easier on hardware than breaker bars. I’ve snapped off a lot of bolt heads to draw that conclusion. It can also help to tighten a bolt a millimeter before you loosen.
I’ve parted out a lot of rusty cars and yes, the seat belt bolts are always tight but I’ve never snapped them.
The internet agrees with me;
It seems that an impact gun does much better job handling an over-torqued nut. The continues force that a breaker bar imposes can easily destroy bolts or studs. Whereas, an impact gun can open nuts with no damage.Nov 1, 2015
https://mechanics.stackexchange.com › ...
Does using an impact wrench instead of a breaker bar prevent In most cases, using an impact gun will be less likely to cause the fastener to fail. Here is my reasoning: Impact guns provide high torque for very short periods of time. This jarring action or "impact" is going to be more likely to free the fastener.Jul 23, 2015
Which is least likely to cause twisting off of rusted bolts? Impact gun or ...
