QUOTE(bdstone914 @ Mar 12 2022, 09:40 AM)
QUOTE(Tdskip @ Mar 12 2022, 08:31 AM)
Noticed after a spirited drive yesterday that the oil light in the combo gauges was flickering at a stop light. Car idles a bit low, but have not seen that happen before and clearly not a good thing.
Light immediately goes out once the RPMs go over 1000 and stays out.
Engine has good power, doesn’t smoke, and is generally an enthusiastic performer.
Any thoughts before I assume it is rebuild time?
Thanks in advance for the help.
I would put an oil pressure gauge on it to see the pressure at higher revs before assuming you need a rebuild.
Idiot light sender has always been sensitive to pressure variance at low RPM. The oil pump is a positive displacement gear pump. Output is directly proportional to RPMs. 10 psi per 1000 RPMs is the generalization for acceptable oil pressure but down an the low end near idle you won't necessarily get that.
However, if your RPM's are dipping down at 800-850 rpm you will end up very near the threshold of the idiot light sensor with some wear in bearings, oil pump condition, etc. From the Haynes manual the oil pressure switch is set to come on between 2- 6 psi but there is a lot of variance in that spec and I'm sure some sensors are probably more like 7-8 psi with production variation.
Make sure vehicle idles at least 900 RPM but better to put it toward the high end spec of 950.
