mlindner
Mar 13 2022, 12:06 PM
I've been thinking about this for a year. 3/8 plexiglass with routed edges to hold filter in place. View of engine is a lot more interesting. Mark
infraredcalvin
Mar 13 2022, 12:09 PM
Looking good!
BillJ
Mar 13 2022, 12:19 PM
Nice. Have that style on mine too. Got them from Rix Parts.
mlindner
Mar 13 2022, 12:25 PM
Love those Bill, did not know of them. Mark
914Mels
Mar 13 2022, 04:24 PM
QUOTE(mlindner @ Mar 13 2022, 10:06 AM)
Plexiglass isn't the best choice around fuel. The fumes will affect the acrylic and you'll tend to see cracks start forming at any drilled holes you make. Hate to lose an expensive engine to a chunk of 'glass going down a carb. Any back fire through the intake could cause quite a mess. Maybe put them on only for car shows.
Mark Henry
Mar 13 2022, 04:40 PM
QUOTE(BillJ @ Mar 13 2022, 01:19 PM)
Did you cut down the RIX rain shields?
Rix rain shieldsIf anyone drives their six 100-200 miles in a single go, 2-3 times a week I'd love to hear a review.
I've thought about getting a set, but just for shows. I just don't think I could trust them long term.
Front yard mechanic
Mar 13 2022, 05:14 PM
I would like these on my 4 cyl
BillJ
Mar 13 2022, 05:42 PM
Yes they are a version that he plans to sell and has a few sets. They were just developed. I have not really run with them yet so i cannot give you a review.
roblav1
Mar 13 2022, 06:38 PM
I have rainhats on my PMO46's but never liked them. Practical? Yes. I ran the old K&N flattops for years in all kinds of bad weather in 911s without issue.
BillJ
Mar 13 2022, 06:43 PM
I am going to dyno with and without and see if i have an appreciable difference.
Krieger
Mar 13 2022, 10:34 PM
QUOTE(BillJ @ Mar 13 2022, 04:43 PM)
@BillJ does that mean your going to not have anything above the carbs? I ask because I did a dyno with the rain shields and air cleaners on and without anything in place. I do not want to say what my results were until after you report your results.
ndfrigi
Mar 13 2022, 11:34 PM
Just wondering if there is also available for 914-4 dual carb clear cover?
BillJ
Mar 14 2022, 05:45 AM
Car is only track so it has historically only run with velocity stacks amd nothing else. Between runs the PO used tennis balls to cover them.
As for type 4 variants you would jave to check with Rick.
Mikey914
Mar 14 2022, 03:04 PM
We sell in ABS
https://914rubber.com/black-carburetor-rain-hat-setCan pull you a set in acrylic may take a we weeks. I did do a set in silver I'll post up a pic later.
MArk
gandalf_025
Mar 14 2022, 04:14 PM
I remember seeing quite a few original plastic air cleaners
melted from backfires..
This is an mild example of damage..
Most I have seen were far worse..
BillJ
Mar 14 2022, 04:20 PM
Is that the bottom conponent or the "hat"? Not sure what we are looking at there?
BillJ
Mar 14 2022, 04:24 PM
Or perhaps you are talking about the big plastic air cleaner shroud that goes on the original 2.0? These are not made of that soft a material so doubt that it will be an issue with these.
Either way i am running 60 minute sessions at most and will always be inspecting after each session. If backfires are happening that much i will be pitting anyway. Ymmv.
Fir
gandalf_025
Mar 14 2022, 04:29 PM
The inside of the bottom of the factory air cleaner.
A couple of good backfires and they melted..
gandalf_025
Mar 14 2022, 04:35 PM
They also used plastic velocity stacks on some cars..
Seen a few melt down into the carbs.
This carb has a plastic stack on the top, a metal one
in the middle and I think a plastic one on the bottom.
BillJ
Mar 14 2022, 05:09 PM
Ok that makes sense. All MFI cars are plastic stacks right? Something to watch for in any event. With the clear should be able to see the result and specific cylinder very fast.
Justinp71
Mar 14 2022, 08:05 PM
I was thinking about doing those, but I like with the rain hats you can dump the oil vent breather back into the motor. Made my garage smell a lot better... maybe can figure another way to dump the fumes back in...
Literati914
Mar 14 2022, 09:16 PM
Can I have the ugly rain hats off your six, so I can install ‘em on my /4 .. and see how many people believe I’m rollin’ a six!!
