Aaron Cox
Aug 1 2005, 02:02 PM
looking to buy a long metal rear valence..... would like to know what years they came on?
was it just 70? 71 too? 72??
AA
BTW - i know they only fit 1.7's.... and another one for /6's......
going to mod it anyway.....
smg914
Aug 1 2005, 02:07 PM
1970 and 1971 and it was revised sometime in 1972.
Grimstead
Aug 1 2005, 02:09 PM
What other types of valences were there?
Aaron Cox
thank you steve....
looking for a 70-71 rear valence
Aaron Cox
Aug 1 2005, 02:13 PM
QUOTE (Grimstead @ Aug 1 2005, 01:09 PM) |
What other types of valences were there? |
3 types
1 long style, with a large hole for a 6cl exhaust,
1 long style, small porthole for early 1.7 exhaust
1 styele, short seen on late 71-76 models (most common), has a notch for the tailpip
echocanyons
Aug 1 2005, 02:32 PM
My 72 has the prothole valance, I have no reason to believe it is not original
McMark
Aug 1 2005, 02:33 PM
I don't know about the hole size between the 4 and 6 long valences, but the hole is clearly farther to the left on the 6.
McMark
Aug 1 2005, 02:35 PM
Here's pictures of an original six on the car and an original four on the ground.
Brent
Aug 1 2005, 02:46 PM
[QUOTE=McMark,Aug 1 2005, 01:35 PM] Here's pictures of an original six on the car and an original four on the ground.
Damn that look is sweet! I was searching my "borrowed" pics for the same image.
Arron, which one are leaning towards? I've alson seen a double port from a pic from WCC. Here it is:
Grimstead
Aug 1 2005, 02:49 PM
QUOTE (Aaron Cox @ Aug 1 2005, 01:13 PM) |
QUOTE (Grimstead @ Aug 1 2005, 01:09 PM) | What other types of valences were there? |
3 types
1 long style, with a large hole for a 6cl exhaust, 1 long style, small porthole for early 1.7 exhaust 1 styele, short seen on late 71-76 models (most common), has a notch for the tailpip |
I seeeee, thanks for the info. I just have the notched one
VegasRacer
Aug 1 2005, 03:12 PM
Aaron - A few months ago I was also looking for a wide style early rear valance.
I ended up buying mine from
E.A.S.Y. They said they had a few more in stock. What I got was not perfect. That was not a problem for me since I also planned to do some custom mods. All it needed was a can of brake cleaner to get off a layer of grease and oil, media blasting, some cutting and welding to relocate the exhaust hole, some
and a little bondo, sanding, primer and paint.
Aaron Cox
Aug 1 2005, 03:14 PM
thats exactly what im doing....
thats Jims car. i have a dual out triad, id like to fit under an early valence
AA
SLITS
Aug 1 2005, 03:50 PM
QUOTE (VegasRacer @ Aug 1 2005, 02:12 PM) |
Aaron - A few months ago I was also looking for a wide style early rear valance. I ended up buying mine from E.A.S.Y. They said they had a few more in stock. What I got was not perfect. That was not a problem for me since I also planned to do some custom mods. All it needed was a can of brake cleaner to get off a layer of grease and oil, media blasting, some cutting and welding to relocate the exhaust hole, some and a little bondo, sanding, primer and paint. |
Ya wuss....ya coulda had the ones I had cheap and done the same thang.......
VegasRacer
Aug 1 2005, 04:04 PM
QUOTE (SLITS @ Aug 1 2005, 02:50 PM) |
Ya wuss....ya coulda had the ones I had cheap and done the same thang....... |
Yeah. I know that now. The one I got from EASY turned out to be more work than I expected, but still less than either of yours would have needed.
Don't feel bad Ron. I promise I will hit you up when I need a special favor or a rare part. I try to keep all of the 'A' listers like you in reserve until I really need them.
I know that next time you might not be in such a generous mood.
If I have to I'll challenge you to a race from Kingman to Oatman - double or nothing.
rhodyguy
Aug 1 2005, 05:00 PM
i should think an original 6 version would be kinda valuble to cut up.
k
Porsche Rescue
Aug 1 2005, 05:47 PM
Performance Products catalog (p. 146) shows reproduction fiberglass rear valances. They show a 914 six "deep" valance ($90)
They also list one with no cut out but don't show a pic ($75). It is likely the deep valance. Might be worth a call if you don't have to have metal.
SLITS
Aug 1 2005, 05:51 PM
QUOTE (VegasRacer @ Aug 1 2005, 03:04 PM) |
If I have to I'll challenge you to a race from Kingman to Oatman - double or nothing. |
I won't miss any apexes this time
Plus, I'll install my patented "Blue Flame Seat Heater and Turbo Boost Modification" for more power
VegasRacer
Aug 1 2005, 05:56 PM
QUOTE (SLITS @ Aug 1 2005, 04:51 PM) |
I'll install my patented "Blue Flame Seat Heater and Turbo Boost Modification" for more power |
You are gonna need more than a burrito for lunch if you want to have a chance.
Mueller
Aug 1 2005, 06:00 PM
anyone know why the design change?
too much heat build up?
exhaust pipe vibrated against valance too much with it surrounded 360°???
well????
SLITS
QUOTE (VegasRacer @ Aug 1 2005, 04:56 PM) |
QUOTE (SLITS @ Aug 1 2005, 04:51 PM) | I'll install my patented "Blue Flame Seat Heater and Turbo Boost Modification" for more power |
You are gonna need more than a burrito for lunch if you want to have a chance. |
I went to the road racing school of "How to block without looking like you're blocking"
smg914
Aug 1 2005, 06:12 PM
QUOTE (Mueller @ Aug 1 2005, 04:00 PM) |
well???? |
Not only did it cause the engines to run hotter because it didn't allow the hot air to escape, it also acted like a snow shovel in the winter climates and snow, ice and gravel would accumulate up inside the large valance and it would actually over time begin to hang lower in the middle and become disfigured.
VegasRacer
Aug 1 2005, 06:14 PM
Blocking won't help when you are in 2nd place in a two car race.
Next you're gonna try and blame that sweet, innocent girl you had as a passenger.
redshift
Aug 1 2005, 06:47 PM
QUOTE (Mueller @ Aug 1 2005, 08:00 PM) |
exhaust pipe vibrated against valance too much with it surrounded 360°??? |
That is what my guess has been, but it's also easier to build the car, a little more modern, and prolly cost $2 less to make.
M
Porsche Rescue
Aug 1 2005, 07:39 PM
One more theory: deep valance would likely have to be installed after power train, whereas notched valance could be installed first. No idea if that would matter for production efficiency.\
Edit: Maybe that's what Miles means by "easier to build".
Kargeek
Cooling and snow and crud build up was one consideration with the early cars- I dont care I like the looks of the early pan, especially with a custom dual outlet.
My car is a four with a deep six pan and exaust tip.
The factory had a part number for the early valance with cooling slots- check this out from my early parts guide. I was never able to find one or hear of one ever installed on a car. DH
MattR
Aug 1 2005, 08:08 PM
Aaron, maybe you could add some RUF style openings like #9 ? It may go with the louvered rockers.
Kargeek
Aug 1 2005, 08:28 PM
Aron,
Cheese grater rear valance - Three or four vertical rows of louvers just below the area of the license plate area - option is to match the angle areas of the bumper.
DH
Aaron Cox
Aug 1 2005, 09:59 PM
wow - never seen that before....
BTW dave - i plan on doing the cheesegrater rockers also....but, whered you do them and what did it cost?
thanks all
AA
Garland
Aug 1 2005, 11:02 PM
Aaron here a another picture for you.
Aaron Cox
Aug 1 2005, 11:09 PM
QUOTE (Garland @ Aug 1 2005, 10:02 PM) |
Aaron here a another picture for you. |
exactly!
tirad + deep valence..... plus A8 chrome tips
got any advice for modding it for the triad? how much did you have to move the hole? and how did you duplicate it on the opposite side?
Garland
Aug 1 2005, 11:43 PM
QUOTE (Aaron Cox @ Aug 2 2005, 12:09 AM) |
QUOTE (Garland @ Aug 1 2005, 10:02 PM) | Aaron here a another picture for you. |
exactly!
got any advice for modding it for the triad? how much did you have to move the hole? and how did you duplicate it on the opposite side? |
This was a 6 valance, and I had to move the hole slightly outboard and weld in a plate to cover the difference. I trimmed the Triad tips off about 3", installed the valance and outlined the locations for the holes from the backside of the valance. The exhaust is very well made, but it, or the car was slightly off on side to side height. So a slight shim on one trans mount, and a extra washer at the engine bar made it correct. I left about a 1/2 " clearance around the pipe after increasing the size to fit the A8 tips. The holes are not round since the valance is angled. Slightly oval cut.
By the way thanks for your post, or the one you where in, on the Triad a while back it helped me make my mind up on what to buy.
The reason I cut a 6 valance was it had been cut before to fit a 4!. Hard to think the PO did that.
Kargeek
Aug 1 2005, 11:50 PM
The dual outlet look is so "bitchin" (you can tell how old I am with that statement...I had my louvers punched by an outfit in Stanton, CA- Sir Michaels Louvers – this was back in the 80’s. Boyd Coddington Hot Rods was down the street. He may still be in business.
I can ask my buddy at SoCal Speed Shop in Pomona if he can help you out- we have a number of contacts with a louver press. Dave H
ChrisFoley
Aug 2 2005, 04:32 AM
Back when my race car ('70) was still a street car I modified the deep rear valence for improved cooling. I made two rectangular openings and added expanded metal taken from an engine lid. I still have it stored somewhere.
redshift
Aug 2 2005, 05:02 AM
QUOTE (Porsche Rescue @ Aug 1 2005, 09:39 PM) |
Edit: Maybe that's what Miles means by "easier to build". |
These cars were marketed in the early years of focus groups, and marketing consultants... along with all those much needed upgrades, the industry got better bean counters.
Ok, I nominate Garland's car for "bitchinest 1.7 with a triad"
That is very nice.
M
Pat Garvey
May 7 2006, 09:48 AM
QUOTE(echocanyons @ Aug 1 2005, 12:32 PM)
My May '72 production 914 HAD it also, but was destroyed by vibrations from a Bursch muffler. Been using the notched valence for quite a while, but really would like to go back to the old style.
Katmanken
May 7 2006, 10:25 AM
Kargeek,
Thats weird....
My parts book doesn't show that picture OR that louvered valence....
Must be multiple books....
What else you got unique in that book of yours?
Ken
Leo Imperial
May 7 2006, 02:13 PM
This thread is approaching a year old.
Did Aaron ever do this to his car???
McMark
May 7 2006, 02:20 PM
It's funny, because I just looked up this old thread for a project I'm working on. And the next day, it popped to the top.
I think Aaron did it because he bought an early valence from me.
