930cabman
Mar 13 2022, 04:34 PM
I have not been having luck finding a source of exhaust pipes, without heat exchanger jackets. At $2.k for a new set of S. Stl. heat exchangers, there must be other options
thanks
Shivers
Mar 13 2022, 05:02 PM
Mark Henry
Mar 13 2022, 05:33 PM
Performance
Tangerine is the best, 4-2-1 header, tube size and muffler options. IIRC a heater box kit. Steel, ceramic coated
Marty makes a nice 4 into 1 header, no muffler, IIRC they are sold through AA. Steel, ceramic option
European Racing headers another 4 into 1, no muffler. Steel, header paint.
There's a couple ebay units, rip off of Marty's header and they don't fit worth a
930cabman
Mar 13 2022, 05:43 PM
Thanks guys, I was hoping for something on the cheap, or even somewhat reasonably priced.
DIY?
930cabman
Mar 13 2022, 06:08 PM
QUOTE(930cabman @ Mar 13 2022, 05:43 PM)
DIY?
It's looking like Marty has something affordable, I will call him this week.
thanks again.
914Sixer
Mar 13 2022, 06:26 PM
I have a set of factory 2.0 exhaust with out the tin. Be tomorrow before I can get some pictures.
rhodyguy
Mar 13 2022, 07:17 PM
If you don't care about heat, Mark's piping is the way to go on the cheap.
Mark Henry
Mar 13 2022, 07:22 PM
Headers are the best and most bolt on power for the buck.
They don't do a lot for stock-ish builds (7 to 15%), but do add 20-30hp+ on a stroker.
Pay Marty for the ceramic coating, it's worth it.
914Sixer
Mar 15 2022, 12:52 PM
Finally got to warehouse for pictures
Van B
Mar 15 2022, 01:39 PM
QUOTE(Mark Henry @ Mar 13 2022, 09:22 PM)
There are several benefits to ceramic coating any exhaust that go beyond the heat insulating factor.
The biggest one for me is the superior resistance to galvanic corrosion. Since the coating is so thin, it's thread safe, and can be applied to the whole part. Which means the corrosion you deal with from dissimilar metals like stainless contacting zinc or aluminum is blunted by the aluminum in the "polished" ceramic coating.
930cabman
Mar 15 2022, 01:45 PM
QUOTE(Van B @ Mar 15 2022, 01:39 PM)
I have 0 experience with ceramic coatings, but I am somewhat concerned of the lack of heat dissipation. from what I understand the heat radiation with a ceramic coating is reduced by about 30%. Where does the heat go? Does it stay within the exhaust tubing and promote heat stress/cracking? and thereby a shorter service life?
Van B
Mar 15 2022, 02:31 PM
More of the heat stays in the exhaust gas, due to the low conductivity of the ceramic. Also, the manner of application "seals" the metal which actually reduces the heat exposure and subsequent oxidation of the metal. Regarding your concern, it is important headers are coated inside.
Post cat, enough heat has dissipated that you really only need an outside coating to reduce heat soak on other parts of the car; like the fuel tank or suspension.
For cars like the 914, it's more of a judgement call based on the build as to when you no longer care about inside pipe coating. These engines can't survive the same heat levels of modern cars anyway.
930cabman
Mar 15 2022, 05:30 PM
Being a piker by nature, I am looking for cheap. I am considering a set of used stock 2 liter pipes with cast ends. The headers I have seen appear to have potential interference issues with shifter rod, ...
