I order up a leak down tester to get a better idea what was going on with my 2056.
I watch a few videos on HOW to Do a leak down then off I go to give it a try...
I order a OTC leak down tester from amazon for about 75 bucks . They have cheeper ones in the 35 dollar range but I had good luck with OTC In the past when I was an auto tech in 1990's
Its not so scary once you do a few. Really quite EZ
Here is how I did it:
Today I performed a leak down on the 2056. OTC tester @90 psi Cold engine with the following results.
First I pointed the distributor so the rotor was inline with the #1 spark plug lead by tuning the engine over with the plugs out. Looking for TDC on the compressing stroke
Installed the tester on plug 1
Placed in first gear and parking brake on.
Calibrated the tool to 90 PSI
Hooked up the test lead for #1
1) 85 PSI
2) 85 PSI
3) 85 PSI
4) 85 PSI
THE CHART shows 90 psi 5-8 % leak down across the board
https://www.youtube.com/watch?v=j2PUvsbA2Yw
