QUOTE(IronHillRestorations @ Mar 18 2022, 11:33 AM)
What kind of exhaust nuts are you using? The copper coated flange nuts are usually locking type, which will make the studs back out.
Use non locking flange nuts, and milk of magnesia on the threads.
I don't think locktite works on exhaust studs.
QUOTE(Krieger @ Mar 20 2022, 11:14 AM)
When you go to install the exhaust system put antiseize on the exposed thread and nuts
thanks for the input, yes the nuts on the ones that backed out were those self locking copper flanged ones. I went ahead and installed all 4 that came out , and i have new flanged but not locking type nuts to use when i reinstall the HE this week. In the past i have seen the nuts that dont lock back ofd and loosen then you get a loose HE and leaks, so hard to say which is worse. This should be back on the car saturday, i am just waiting for the new clutch disc to arrive, but i pulled and replaced all the leaking seals including RMS and the trans output seal. I cant believe there wasnt one supplier that could get me a clutch disc in a few days. every one of htem was quoting a week-10 days. heck i would have paid a bit more if i could have gotten one from fLAPS but none of them had the ability to order one, so it was either ebay or AA.
