the full story is i pulled the transmission to figure out if i had a RMS leak or transmission output shaft seal leak, and it was both, but mostly the transmission seal was more of an issue.
So… first off, now in reassembly, and when it came out there was no felt washer , and i know where it should be but my question is, should the pilot bearing be flush to the flywheel on the side of the felt washer or should the bearing be pushed forward to allow the felt washer fit flush with flywheel surface ?
second part is can i reuse the flywheel bolts? i have a new flywheel washer , and i have new bolts from type4store, but they don’t have the ridges on the flange like the old one(old ones are only 9 months old)
picture shows the new pilot bearing installed but not all the way to back of flywheel(i should say it’s flush to the back on side of where the felt washer will go and washers bolts etc)
