robkammer
Mar 20 2022, 11:30 AM
So, I have three fuse panel indexes, or lists of what powers what. And all three are different. For example, for fuse #8:
List 1: 20 amp feeds Fresh air blower fan relay and horn relay
List2: 16amp feeds Lighter, heater control lamp, some gauges, L&R rear brake lights and back up lamps, clock
List 3: 8amp parking lights Left, possible marker lights left.
My #8 , with a 16amp fuse is only hot with the key ON, so the clock would not make sense.
The car is a March 1974 LE, can someone direct me to yet another diagram?
In the little bit of driving I was able to do in the car everything seemed to be working with the exception of a headlight/fog light issue. I'm becoming more baffled the deeper I get.
914Mels
Mar 20 2022, 05:01 PM
Fuse 8 on your car should feed the wiper switch, cig lighter, blower motor and the blower indicator light. All red/black wires except blower light is red/white which picks up power at the cig lighter connection.
dlee6204
Mar 20 2022, 05:11 PM
robkammer
Mar 20 2022, 05:54 PM
Thanks, That is one of the three that I have, and I have to believe that Jeff has the best insight into the 914, but why is there such a difference between diagrams? For now I just put it all back together after cleaning up the hack work. Discovered that the fuse panel was broken so I'll order one and swap it out after I get the car back on the road and settled in.
Spring is happening, starting to feel pressure to get the cars back out!
Dave_Darling
Mar 20 2022, 06:31 PM
Part of it is early vs. late. I think up through 72 the fuses had one layout, and in 73 and later they had a different layout. The later fuses don't have any 20A ones in the fuse box, just 8 and 16.
--DD
robkammer
Mar 21 2022, 07:17 AM
Thanks agin: I'll stick with Jeff's rundown. I purchased a couple of his harnesses, they are terrific!
