mb911
Mar 20 2022, 06:47 PM
I have a foam rear spoiler from my 928 s4 which is the same material as the 914 bumper seals.. what has happened specifically is the studs have pulled out and on the 928 forums there is talk of using an epoxy to install stainless rivnuts as a new way to affix them.
I am looking for something that will work properly.
Thoughts?
Van B
Mar 20 2022, 06:49 PM
I imagine 3M window weld is up to the task. Just make sure you check the date on the tube.
And also, know that it will stick to EVERYONE and EVERYTHING
mb911
Mar 20 2022, 07:00 PM
QUOTE(Van B @ Mar 20 2022, 04:49 PM)
I had thought about that as well.. 2 votes so far for that.
Mar 20 2022, 07:22 PM
We bought some of that to attach a door bar to the inside door skin. It’s pretty strong stuff, and very messy if you aren’t careful.
Geezer914
Mar 21 2022, 05:30 AM
JB Weld, I use that s__t on everything!
roblav1
Mar 21 2022, 07:28 AM
Aeropoxy, then mix up some silica until peanut butter consistency.
mlindner
Mar 21 2022, 11:58 AM
Ben, if you can mount the rivnut to a small metal plate first then epoxy the plate into place. We use that often, works great. And best use 24 hr epoxy to cure, longer the stronger. Best, Mark
jmalone
Mar 21 2022, 01:05 PM
Ben, Google West System epoxies. They have epoxies formulated for flexible substrates ( G-Flex) that work very well. I would consider increasing the surface are of the bond with the addition of a reinforcement like a thin piece of stainless bonded to both the bumper and the rivnut. This West System has a great support network. Good luck!
