Want to remove the rear discs. Of course a couple of the one out of two bolts that hold the disc onto the hub are impossible to remove. Each one rusted with a messed up Phillips head. So, I was able to drill out the head of eachr of the remaining bolts and now I’m stuck with each hub having one bad thread.
1. Is it difficult to remove each hub? I have another car that I could swap hubs with. Looks like a bunch of work.
2. Or, is there a way to create new holes and threads each of those in the existing hubs?
3. Use just one bolt on each disc to hold it to the hub and then once the tires back on with the Lugnuts that’s enough to hold the disc in place on the hub.
4.Better ideas?
Picture one is the remaining portion of the bolts stuck in the hub. Picture two is the good threaded hole in the hub- reusable.
Thanks. Todd Click to view attachment
