QUOTE(930cabman @ Mar 23 2022, 07:45 PM)
Assuming everything being the same, jets, E tubes, venturis, .... will a 44IDF perform the same/similar to a 40IDF?
Not really.
44IDF's have 10% more circumference around the butterfly diameter. This is where the air begins to flow at early transition from idle to mains.
At WOT 44IDF's have 21% more flow area. The increase in area acts to slow down air velocity though the carbs, and in the manifolds. Even if you speed up the airflow at the waist of the venturi with a smaller venturi, the airflow will slow again once it reaches the larger throttle bore of the 44's, more so than it will slow in the 40IDF.
Neither of these numbers seem huge at first glance, but they are significant changes between the 40IDF's and the 44's. if they didn't matter, there would be no point in having two different carb bore / throttle plate sizes. The simple fact is the 44's are the big brother to the 40 IDF's and were intended for larger displacement motors.
There will always be differences in throttle response. Can you tune around them. Yes - with compromises on the low end drive ability.
