63acornwall
Mar 22 2022, 06:13 AM
I have a new blinker ( turn signal flasher ) relay to fit , old one fails to blink the dashboard indicator lamp .
My '75 car has an aftermarket fuse system fitted - see pic - assume I must remove this to get at the blinker relay - but not sure how - or where relay is located ??
914Sixer
Mar 22 2022, 06:20 AM
What year car? Different locations. Seeing homemade modifications . Drop two middle phillips head screw and see what is back there.
Chris914n6
Mar 22 2022, 10:43 AM
The two outer most screws release the panel. Then the black rectangle is the flasher relay. Seeing the new connectors... double check the wiring.
dhuckabay
Mar 22 2022, 10:48 AM
Where is the relay on a stock 74?
QUOTE(914Sixer @ Mar 22 2022, 05:20 AM)
63acornwall
Mar 22 2022, 04:10 PM
Ok , took out the 2 outer screws and managed to drop panel a couple of inches . There were 2 relays , one had tags matching up with a replacement that I bought from a 911 shop . It was velcro’d onto the panel . I removed battery ground lead , swapped relays , reconnected battery , relay tested out fine . The hardest part was to get the panel back in , hard to see where screws were mounted while laying on back with head tucked under steering wheel - but done . Thanks for advice , not covered by Haynes manual !!
