QUOTE(bdstone914 @ Mar 23 2022, 11:48 AM)
If you cant get them all in I would not sweat it. That pad is not going anywhere.
I couldn't get all the ones from the underside in, but I got enough in that it's secure.
You might need longer screws. I can't remember what size I used, but the one that came with the kit were not sufficient IMO. You need to be able to pry to adjust in place either with the awl or the screw itself. Also make sure the back side of the screw hole is actually clear. I seem to recall that the manufacturing process leaves some material on the back that may interfere with your ability to get the screw lined up and/or started.
Good luck.
