74ravenna
Mar 24 2022, 07:29 AM
Hi All.
I'm reinstalling the Oil Pressure Switch that is located on top of the engine next to Cylinder #4.
Does it require a washer?
Any specific torque setting?
Any sealant?
It's been a couple years since I've been able to do any serious work on the reassembly of my motor and I've forgotten a lot.
Plus, the research I've done doesn't clear up the mystery for me.
Thanks.
falcor75
Mar 24 2022, 07:36 AM
I only use a copper washer. No sealant.
GregAmy
Mar 24 2022, 08:11 AM
It's a tapered pipe thread; the tapered threads seal it. No washer, as that is not a sealing surface.
Some use Teflon tape to help seal the threads (shouldn't be needed) but check the electrical grounding (shouldn't be a problem).
If you can screw the switch fully down to the case and it still doesn't seal, you have a different problem, maybe buggered threads in the case or switch.
74ravenna
Mar 24 2022, 08:58 AM
From Sweden to Ct.! Gotta love it.
Thanks Guys.
914Mels
Mar 24 2022, 10:53 AM
Check your switch. If it doesn't have tapered threads you were sold the wrong switch. The water cooled engines us a switch with a copper gasket. The threads are longer too.
