Ed - the stock 2.0 injectors simply unplug. I assume it's the one that looks like this:
You may need to unseat the rubber boot, and then give a gentle pull up. The original wires, connectors, and rubber boots are pretty crunchy at this point and can break, but there are also repair kits available if you need to fix it.
Are you trying to remove the entire injector to replace the rubber hose, for example? Then you also need to remove the injector retainer. That's held on by that circular metal piece with a single 10mm nut holding it at the top. Normally the rubber hose doesn't have much room to give in that space, so even if you unbolt the injector retainer you may have a hard time removing the injector itself. So you may want to try to disconnect the hose from the rail first, remove the retainer nut and retainer. The injector will pull out at that point.
If you replace the injector hose make sure to use a fuel injection style clamp (EDIT, like the ones in ndfriqi's pics) and replace the rubber injector O-ring seal.
