QUOTE(Tdskip @ Mar 29 2022, 03:16 PM)
QUOTE(Tbrown4x4 @ Mar 28 2022, 05:08 PM)
Brake fluid will pump through a grease gun. You’ll hate cleaning grease out of a rear caliper.
That was my concern with the grease approach.
Given that you are going to replace the seals anyway it is OK to get destructive on getting the pistons loose so long as you don't scratch the pistons or bores. Sometimes heat is needed alternating with compressed air. Just make sure to take care when using high pressure air as the pistons will come out with a lot of force.
On my Lotus Elan that sat in a warehouse in Fallbrook since 1993 I had to cut a grove that allowed me to get a punch in to rotate the piston.
I have used the compressed air approach successfully. I totally agree that "the pistons will come out with a lot of force". Enough, in fact, to crack the front edge when they hit the other side. Get a good chunk of wood in there before, "quickly checking if this will work". Ask me how I know ...
