QUOTE(frostyf @ Mar 27 2022, 04:07 PM)
QUOTE(914Sixer @ Mar 27 2022, 05:37 PM)
They are NOT 914 shocks. 911 indicates they are for a 911
I thought that but then read, probably incorrectly, that some of the 911 inserts fit 914 applications. I take it that's wrong. I guess i need to go with a new set of yellows then!
That’s only true for 911 boge front struts. You can use Koni 914 or 911 inserts that are designed for boge struts.
I am currently running Koni yellow HD 914 front inserts in 911 3.5” boge struts. They are valved a little less than the Koni HD 911 inserts.
I was also told that new Reds are no longer available, so your only choice is Yellow or get them revalved to red specs. The Koni yellow are not as stiff as Bilstein HD, but beware Koni’s do not have built in bump stops like Bilsteins do. They have to be externally added. I also had to modify my Rebel Racing rear coil overs to work with Koni shocks. They were only designed for Bilstein shocks.
