QUOTE(Lockwodo @ Mar 29 2022, 06:50 AM)
I checked fuel pressure yesterday with the engine idling. It was 29 PSI which is within spec, so that's good. I then shut off the engine and observed pressure drop. The pressure dropped from 29 to 25 PSI after one minute, and dropped further to 20 PSI after about 6 minutes, and was at 10 PSI after an hour.
Is this normal/acceptable, or do I have a fuel leak I need to chase? If I'm dealing with a leak, is the most likely culprit the fuel pump check valve, or a leaky injector, or?
Thanks in advance!
it is quick.
during recommission of my 74 1.8 we installed a new two port pump in location of old pump near engine underneath. i was holding 20 psi at end of day after a start in morning. admittedly L jets have slightly higher pressure in line at 35 to start with.
its possible your fuel pressure regulator is leaking down rather than the pump.
but it could just as easily be the pump and its check valve.
you can install an inline check valve after the pump and do a test.
pretty cheap to buy and fit just to do the check up.
that will tell you which one it is.
how old is your fuel pressure regulator.
might be handy to have a spare sitting around for just in case.
