(Edited from original ad, decided to split this up)
Hi, I'm normally a 912 guy but I have a 1.7 long block that I'm not going to need. I was originally going to use it in a 912, but plans have changed for that car.
(carbs have sold separately, and I'll be removing the VW 411/412 heat exchangers seen in the photos and video)
I bought it years ago from a guy who was converting his 914 to electric. It was running when he removed it, and I've had it running on a stand.
Included is most of a set of L-jet fuel injection, which was on the engine when I bought it, despite not being correct for a 1.7. I don't have the ECU.
I have video of it running on the stand you can see here: https://youtu.be/S9EkxNjSMCU
That video is from a couple years ago; the engine has been in storage since then. I can do a compression test, etc (though I don't have a leakdown tester) if anyone is seriously interested.
Asking $500. Not including the stand or trans case seen in the video, but does include a good used clutch and pressure plate.
Located in Portland, OR. Pickup would be great, but I can help ship at buyer's expense.
thanks,
Dave
