Ishley
Mar 31 2022, 06:13 PM
I’m about to weld in and close up the long on the drivers side. I have welded in the nuts at the bottom off the inner rocker cover and checked the alignment of the outer rocker cover. My car did not have steel covers only some cheap fiberglass covers with no steel under it. The mount was not right so I was not be able to use it as a guide.
The mounts to the fender have me a little baffled. The diagrams have a tapping screw, washer, rubber spacer and a speed nut. My new RD rocker cover does not have a hole at this location.
Question: Is the mount accomplished by sandwiching the rocker between this or is there supposed to be a small hole drilled in the cover that the screw feeds thru to secure the cover to the fender? It feels like drilling a hole would be more secure… but I don’t want to add a hole to fix if this is wrong. Again… this just has to do with how these rocker covers connect at the fender points. The rest of it I have it all set.
How is it done correctly?
dlee6204
Mar 31 2022, 06:25 PM
The rockers would have a hole on each end for the speed nut. The tapping screw would go through the fender, through the rubber spacer and into the speed nut.
Ishley
Mar 31 2022, 06:33 PM
Perfect! That seems right. I was just about to drill the holes and I thought I’d better ask. Thanks for the response. Where in western NC are you located. Wife and I are thinking about making a run down to Brevard to see some friends in a few weeks. If your close maybe I could stop by and say hello.
dlee6204
Mar 31 2022, 06:48 PM
QUOTE(Ishley @ Mar 31 2022, 08:33 PM)
Please do. I'm just north of Asheville so I'm not too far from Brevard.
Ishley
Mar 31 2022, 06:52 PM
Ok. I’ll let you know when we have a plan finalized. Thanks again for your help!
