I am wiring a push button starter switch, with a covered switch for the ignition.
I have done this before, I didn't use a relay on the start button, but I may have used a HD switch.
What are the lower limits? I have no manual..
M
QUOTE (lapuwali @ Aug 1 2005, 11:03 PM) |
I like having everything shut off with the ignition, however, so I'd wire up a 30 amp relay for everything except the headlights, which would get their own 30 amp relay. Have the main switch shut off the main relay, which also powers the headlight switch, so the lights go off with the main switch, but almost no current goes through the main switch. |
QUOTE (GWN7 @ Aug 2 2005, 01:41 AM) |
We need a tag day for Miles....send you pennies and empty pop bottles.....that way he can afford to buy one of those very expensive Haynes manuels off of ebay.... Zoom Zoom in the morning |
