Ok guys now comes the To Do List for the new ride.
I have to start with the easy stuff since I'm still waiting for my manuals to arrive.
1. Hook up CHT gauge- Done (last Night)
2. Install oil temp sender for 912 gauge
3. Hook up the Sub woofer in the center console (how do you get the console out? remove the shifter?)
4. Remove dash and wrap in vinyl
5. Clean engine and start hunting for the oil leaks.
6. Check valve adjustments
7. Check ignition points, dwell, timing. Is electronic ignition the way to go here?
8. Get a new fuel pump (mine is noisy as hell!)
9. Go for a nice ride
10. Investigate the springs/shocks on the rear (I think there are lowering springs in the back cause the tires have rub marks but they have not rubbed yet for me.
SO what should I do first?
