QUOTE(914Mels @ Apr 10 2022, 12:57 PM)
QUOTE(steuspeed @ Apr 8 2022, 09:23 PM)
I bought the 91847V Pertronix Igniter 2. The bottom edge of the red sensor is supposed to be at the same level as the lower edge of the magnetic pickup ring. It looks like the ring is about 1/16" lower than the pickup. Also, the pickup adjustment is all the way at one end of the range and it is still a slightly larger gap than the spec.
Comments please!
Your distributor plate looks pretty rough, the vacuum advance/retard needs to be able to pull it back and forth easily. The little ball bearing that holds the two plate halves looks like it's grease is solidified. The little braided ground wire it looking pretty sad too. You might also check the mechanical advance while you're in there, try twisting the rotor and see if it snaps back easily. The little felt wick under the rotor should get a drop of oil every tune up. If either of these things aren't working right your timing will be way off.
what a mess,I would suspect the advance plate is all gummed as well and possibly not moving easily,after cleaning that you need to make sure you have the correct coil for this unit and good quality non copper leads otherwise you will damage the module,as per the instructions supplied with the unit ,could be a mention of the spacer which you don't need.
Good luck.
