I've had six 914s, four of which were drivers, but somehow I've managed to steer clear of diving into any front-end projects. Never quite had all the tools I needed, or the parts budget to do it right - and it's a job that intimidated my younger, less organized self.
Well I finally ran out of excuses as I've collected all the parts and tools to fully restore the front suspension along with the car's entire brake system. It's all well neglected and worn, including the brake system which has frozen adjusters on the rear calipers along with a very spongy pedal.
The rear suspension is coming out, eventually. It's already running Koni yellows with 180 lb springs. When I got this 914, I was under the impression the front was also setup with larger torsion bars and Koni yellow inserts, but that ended up not being the case.
My poor car is in desperate need of some bodywork and paint, but I've made the cabin a pretty nice place to hang, and at this point sorting the mechanical bits is far more important than exterior cosmetics.
I love these 4-lug 15x7 ATS wheels that my buddy Dug found for me -
Up she goes -
Worn tie rod inner bushings -
After a fair amount of fussing and cussing, I was able to free the lower steering column. It was all straight-forward from there and the lot came right out -
Growing up we had pickle forks, but I've got a "thing" I'm contending with that makes swinging a hammer a bad idea, so I had to end up getting low impact tools like this -
Speaking of tools, this worked perfectly with my impact gun -
What a dirty mess. The drop-cloth collected most of the crud and since it's old I'll just end up tossing it vs trying to clean it. I kept all the dirt out of the steering rack, but I needed to check to see if the grease was dried out - which it wasn't, and I can't feel any play in the outer bushings (whew!).
Rack grease -
