QUOTE(guytranspo @ Apr 12 2022, 06:33 PM)
QUOTE(r_towle @ Apr 12 2022, 05:52 PM)
I believe you can fit the whole drivetrain from a Tesla into the back of the 914, with transmission, motor, and rear suspension.
Those are 4-5k used.
More power..
I like the idea of keeping a transmission and Porsche suspension.
Tesla motors also require a lot more voltage and complicate battery options.
I agree with keeping the transmission and suspension. The torque of the motor is hard on the transaxle and CV joints. So you need to bring those up to top condition. You are also doing much of the slowing of the car through the drivetrain so parts that are already marginal don't last long.
With the dual AC-34 your peak current will be around 1200 amps though at around 96 volts you will likely have 4-5 96 volt battery packs so outputting that 1200 amps should not be a problem. Your main DC cables are going to be large and you will need dual contactors.
For 120 miles you need around 30kWh of batteries which will could make the car around 100-150 pounds heavier than a 914/6. It all depends on the energy density of the battery.
You will need a small coolant loop for the inverters, it doesn't take much. The batteries should also have a coolant loop. A pump, a fan and small radiator might be all you need in your area.
The cost of doing a 6 conversion seems to be running in 15K range. So the cost of 6 vs EV are about the same. The 6 will require more modifications to the chassis, however, they are "factorish". For the EV you might have to drill few 1/8" to 1/4 holes for mounting, it depends how good you are making brackets that pickup factory mounting locations.
A Leaf motor is the right power range and can be had for $400-800. It will take more engineering on your part. Thunderstruck Motors make a VCU for them
