QUOTE(Halfnelson @ Apr 20 2022, 11:51 AM)
Hi,
Have just purchased a set of FJ114 Standard injectors to replace the ones in my 73 1.7. At some point PO had fitted new injectors but not the correct type. I have a couple of questions for those that have fitted these.
What size seals do I need?
The hose seems short - how did you get round this?
Thanks, Chris
I just fit these injectors to my 1.7 and bought them from rock auto. I got seals from them as well. The engine is still out of the car, hopefully I will install in a week or so. I believe the hoses are long enough. May not know until I run them. They installed ok but it's hard to tell if the bend will restrict flow at all. I do have fairly new pre bent hoses I can swap in if there is an issue.
