Thanks fellas: It is the plenum, not the runners I am thinking that I need. I've attached a photo of that area. I rewired and plumbed the engine bay over the winter, and didn't really pay much attention to where the old hoses went. I had new AA hose package with t a great drawing in hand, so, no problem.
But, the drawing and several advisors have said that the PCV should connect to the plenum, as you can see in the photo I have it where I believe it was before, on the air filter.
I bought the 'F fitting from George and it does not help the situation. The large fitting on my plenum fits a 9mm hose and the pcv is a 12mm. Also the 'F ' fitting is for a 12mm nipple as well.
I don't think running the pcv to the air box would cause much trouble other than an oily air filter, but I would prefer to have this setup as it was intended to be.
So if I need to swap the intake, that should not be to much of an issue.
All thoughts are welcome.
Rob
Click to view attachment Click to view attachmentClick to view attachment
