Have you ever tried cycling the key on, letting the pump run, and turning the key off again like 4-5 times before cranking when hot?
I suspect 1 of 2 things (or maybe both).
1. Fuel flow issue of some sort. dont normally see this as much with a front pump but ethanol gas seems to boil really easily in the fuel rails in hot climates.
2. its a 75 car in California so I assume you are emissions testing it? Possible that its tuned so lean in order to pass emissions that after it heat soaks from sitting its not getting enough fuel to easily start. Maybe try fattening up the idle mixture
Check your fuel pressures when hot.
You could also try adding potentiometer inline with the CHT sensor and dialing up the resistance slightly to see if it eliminates the off idle stumble.
Whatever the underlying cause it it sounds like its lean to me.
QUOTE(Tdskip @ Apr 21 2022, 03:15 PM)
Thanks for all of the responses, I am still very much in the early days of learning about these systems.
This is a 1975 Djet 2 L car, stock engine.
Overall symptom is reluctance to start when hot and it tends to stumble off idle when it’s been running for half an hour or more. Cold start when sitting overnight or having rested for 30 minutes or more after being run a lot is totally fine, so it’s a heat related transient issue.
When cold the car starts without any additional throttle and idle’s is very solid/stable. When the car is hot it takes a lot of cranking to fire, and generally needs quarter throttle open to start. If that doesn’t work I need to floor it and keep it cranking for quite a bit before it will catch.
@superhawk - thanks for the education on the spacer, I had thought that the distance would result in a small but big enough space to change the reading, that was obviously an incorrect on something on my part. Thanks for the better information.
To do the resistance readings just get an ohm meter on the sensor output tank and then run the throttle through range?
