QUOTE(Rand @ Apr 24 2022, 12:10 AM)
I tried to read this. I failed because of overload of info. It has to be as simple as a vacuum leak. It is air getting where it wasn't supposed to be FROM.
yes.
air is getting in from where its not supposed to be coming from.
(thats what the section on AAV in dr djet site is saying.
go straight to section 9.3.1 of link to AAV on dr d jet.)
via the auxiliary air valve. which has stayed open instead of gradually closing.
there is two ways those things can fail.
fail shut = hard cold start.
fail open = really screw with the amount of air the engine is supposed to be getting via the measurement of air into engine by ECU.
i know how L jet works. the AFM measures the amount of air coming in.
how D jet measures air coming in is a bit of mystery to me.
the mechanic he took it to proved that the extra air was the problem by pulling the hose from the aav and plugging it.
as emery says if
@Chupee takes the aav permanently out of the equation by plugging it he solves it. sort of.
but its going to be harder starting it cold.
which is ok.
i'd have to read that d jet article a few more times to half grasp it myself.
you are not alone.
but since i have L jet i can't actually be bothered fully understanding it.
.......someone with experience of d jet problem solving would know what is being said.
and could confirm it or deny it.
i kind of half get what is being said.
i am thinking it hinges on whether 914s have fuel cut off on deacceleration like mercedes benz. that is the scenario being described.
so really i was just replying to emerygt350.
he thought a screwed aav would just be elevated idle. he may be correct.
but it seems a screwed aav on d jet can also cause the hunting idle thing.
i dunno.
it does fit the scenario being described.
a wildly sawing (german for hunting?) engine at idle.
anyway problem solved already by plugging the hose.
but if cold start wanted back - thats another matter.
sounds like he would have to look into the aav valve?
ps
@Chupee says he has a 71 1.7
i seem to remember reading something about the early d jet 914s having fuel cut off.
maybe chupee has that - just like mercs being talked about by dr. dread jet.
learned d jet guys would know this better.
