98101
Apr 25 2022, 03:22 PM
I want to adjust my clutch cable but my car is a bit lower than stock and I don't have a way to jack it up in my apartment parking area.
I see that Walmart has "Rhino Ramps" for about $60 and Amazon has "Race Ramps" for $300. Any experience with these?
emerygt350
Apr 25 2022, 03:26 PM
If you are up to it, just drive the passenger side up onto a curb. Cheap and all your neighbors will respect you. Or at least they should. Just make sure you are really on the curb or grass, not dangling.
Jack Standz
Apr 25 2022, 03:28 PM
emerygt350
Apr 25 2022, 03:32 PM
Oh man, that hurts to even look at. For what you need,just the passenger side. Our cars have the transmission where it belongs, our engines go the 'right' way.
rhodyguy
Apr 25 2022, 03:42 PM
Downtown Seattle iirc. The curb thing would not go over so well. OP, do your CCRs prohibit working on vehicles in the garage? On street DT parking is a bit of a rareity. If you can find it, it's for a very short duration. A decent floor jack is a better option than driveup ramps. Esp in a lowered 914.
98101
Apr 25 2022, 04:28 PM
QUOTE(rhodyguy @ Apr 25 2022, 02:42 PM)
Yes, I'd prefer to do this in the parking garage because there are too many addicts and mentally ill people out on the streets around here. Also the streets and gutters are wet a good portion of the time.
I was thinking ramp rather than floor jack because I'm not 100% sure about the rust situation on this car.
emerygt350
Apr 25 2022, 05:58 PM
Oh man, crazy onlookers are the whole reason to suck it up and curb it!
Jacks are heavy and annoying and you shouldn't ever crawl under a car with only the jack. Buy a cheap plastic ramp from a flaps. They will be easy to haul back into the apartment or the frunck.
However, if your car is too low, you may have issues getting on the ramp.
BillJ
Apr 25 2022, 07:07 PM
Recommend the rhino ramp. Available and cheap. Dont spend the race ramp dollars for this kind if use. I own both and would totally suggest the rhinos for that. Alternatively you can jack it up and use jack stand. Remove wheel for ease of access.
brubou
Apr 25 2022, 07:12 PM
My car is very low and I used to put 2 foot sections of 2x6 in front of the ramps with the edge cut at the same bevel as the ramp so there wasn't any gap. Otherwise my valance would just push the ramps down the street. Get it up on the wood, line up the ramps and it should go right up from there without much hassle.
GregAmy
Apr 26 2022, 05:25 AM
Build ramped/stagged sections of 2x6s. Put a rope handle on them for carriage to and fro. Easy, cheap.
Or these:
https://www.raceramps.com/c/garage-service/
Steve
Apr 26 2022, 06:57 AM
Most major cities have places that will rent you a spot by the hour or day with tools and a lift. Otherwise, it’s a floor jack, jack stands or ramps. I used a floor jack to get my car on the ramps. Harbor freight has small floor jacks and jack stands that will easily store in your trunk.
Shivers
Apr 26 2022, 07:07 AM
Before I had a floor jack and stands I would pull up to the egress of my driveway, parallel to the curb, and put one then two tires on the curb as I pulled up. It was good for clutch cable and stuff. Valve adjustment I had to back it up on the curb to get the other side. It worked until I tooled up properly.
PanelBilly
Apr 26 2022, 07:37 AM
You need to learn about Stews Garage. There’s one in Kirkland and he’s getting ready to open one in Auburn soon. You rent a bay with all the tools you can imagine. I’ve used it several times and the price is very reasonable.
98101
Apr 26 2022, 12:52 PM
QUOTE(PanelBilly @ Apr 26 2022, 06:37 AM)
Oh! I found it here:
https://stewsgarage.com/car-lift-rental/ The fact that they have tools is perfect for my situation.
Apr 26 2022, 01:32 PM
QUOTE(PanelBilly @ Apr 26 2022, 09:37 AM)
I just looked them up. Prices seem very reasonable for what they offer.
seanpaulmc
Apr 26 2022, 02:20 PM
Ramps work.
Photo for reference.
mlindner
Apr 26 2022, 03:30 PM
Yup, love rhino ramps....
MM1
Apr 26 2022, 08:22 PM
After looking at pictures of rhino ramps that have cracked, and looking very closely at their design, I picked up a set of ramps from Harbor Freight which appear like the ones in the picture above with the oval hole in the side.
They have been sturdy and functional for me, but they don’t raise the car enough for me to get much of anything done underneath.
r_towle
Apr 26 2022, 08:35 PM
QUOTE(98101 @ Apr 25 2022, 05:22 PM)
Do it blind, fix it by feel
Get used to it, the 914 requires feel but no looking
