QUOTE(Dave_Darling @ Apr 26 2022, 02:57 PM)
The Pertronix has nothing to do with the fuel pump. Unless some misguided soul plugged the fuel pump directly into the coil, which is connected to the Pertronix.
Stock fuel pump grounding is to the chassis ground point under the relay board. Pumps that have been re-wired will ground wherever the person doing the wiring decided to ground them.
I don't remember how the Pertronix is grounded. If it has a separate ground wire, trace that.
The stock points are grounded through a bit of a long path:
- Points plate to the distributor body
- Distributor body to crankcase
- Crankcase to transmission case
- Transmission case to tranny ground strap
- Tranny ground strap to chassis
- Chassis to battery ground strap
- Battery ground strap to battery ground terminal
Any of these junctions can have dirt or corrosion which will make the ground worse.
You can provide an extra ground point by going straight from the battery ground terminal to the engine case, or straight to the distributor body. You should use a very thick wire just in case everything starts grounding through that, BTW. This will at least allow you to test.
--DD
Thank you Dave....I will check all of these points....I thought my tranny to body ground strap was loose but it was not....just dirty....can being dirty actually interfere with the grounding capability on this strap? I will clean up all of my grounds and report back.
Thank you very much....gg
