Trans going back together.
The only parts salvageable from the old one are the main shaft, intermediate plate and 3 of the forward gears. The old case, all consumables were done. Even the ring and pinion were trashed. If anyone ever tells you a welded diff is a good idea, turn around and walk away...
We changed the gearing a bit to better suit our road courses 'round here. Going with A, HA,N, S. X. We'll see how that all feels.
Click to view attachmentMaster tech Gordon giving the parts a good talking to:
Click to view attachmentClick to view attachmentClick to view attachmentThe huge advantage of getting help from a pro is he's got pretty much every conceivable shim and spacer on hand. No stopping and waiting to order fiddly little parts.
Click to view attachmentShafts are assembled, Pinion depth set, pr-load and RP lash all set. Final assembly tomorrow. Wavetrac is on order and will go in later this summer or over the winter. There's a worldwide shortage of diffs at the moment.
I went from knowing very little about transmissions (I've understood the basic principles, but never torn one down before) to having at least a rudimentary understanding of how a Porsche synchro box works. After I've done it a dozen more times I'll feel comfortable taking one on myself. When you see it done right you begin to understand how precise they actually are. The notion that you can tear it down, measure a couple gaskets and re-assemble isn't true. Maybe if it was less than 10 or even 20 years old, but a 40 plus collection of parts has worn, stretched and distorted to the point that you have to start over with baselining all of the tolerances.
QUOTE(Charles Freeborn @ May 22 2022, 03:48 PM)
QUOTE(wndsrfr @ May 21 2022, 09:32 AM)
QUOTE(Charles Freeborn @ May 20 2022, 04:05 PM)
Aaaaand the carnage:
Click to view attachment Click to view attachmentClick to view attachment Click to view attachment 1st/Rev stack destroyed
So is the 1st /Rev carrier
couple of other sliders,
all the synchros and the ring gear is iffy... not to mention the main case is getting sloppy (main shaft bearing race not secure)
Yeah, gonna cost...
Yep...I've come to the realization that the transmission on a track car with over 200hp has become another consumable....
Certainly a number of components within..
