swood
Apr 28 2022, 08:07 PM
Never been used. Ready to go. $325 plus your choice of shipping from 90807.
bdstone914
May 1 2022, 03:16 PM
I am seeing new cams for about $150. Am i missing something?
webcam new billet price is $365
Regrinds are $155 but 86b can't be reground on a stock cam
jim_hoyland
May 2 2022, 05:21 AM
Hi Steve
For carbs, FI or both ?
How about a 2056 L-Jet ?
Curious…
GregAmy
May 2 2022, 06:22 AM
The 86B is really an aggressive "race cam", designed for higher RPM versus low-end torque. It will make some good power when coupled to the right valvetrain but I suspect you'll find that it's not a particularly "streetable" cam for a daily driver (I'm not saying it can't be used for it, but that's not what the grind is for.)
I'm running an 86B in my dual-Dellorto-equipped racer, makes good power through 6500 RPM.
I'd personally advise against it for a D-Jet implementation, since you just don't have any way to efficiently compensate for the lift/duration.
FAT makes a "EFI 440" cam for fuel injection; I'm running it in my 2056cc street car with Microsquirt. 0.398" total lift (@1.3x ratio), 252 duration, no overlap at 50-thou. Nice low-end street torque and good power through 5500, HP peaking high 4000s.
jim_hoyland
May 2 2022, 06:44 AM
Thanks
Nice explanation….
motorvated
May 2 2022, 12:06 PM
QUOTE(jim_hoyland @ May 2 2022, 06:44 AM)
Thanks
Nice explanation….
Any valve train modifications required when using this cam on a carbed 2.0 liter. Does this cam come with the cam gear? Thanks, Mike S.
swood
May 2 2022, 06:19 PM
QUOTE(motorvated @ May 2 2022, 11:06 AM)
Thanks
Nice explanation….
I will include the cam gear, forgot about that, also not used.
Can't really speak to changes on your geometry. Really depends on what you're running now.
motorvated
May 2 2022, 06:25 PM
QUOTE(swood @ May 2 2022, 06:19 PM)
Thanks
Nice explanation….
I'm running all stock valve train components.
swood
May 2 2022, 09:17 PM
QUOTE(motorvated @ May 2 2022, 05:25 PM)
Thanks
Nice explanation….
Just let me know if you want it. I can't really speak to your application.
MartyYeoman
May 2 2022, 09:55 PM
Whoever buys this, make sure you run WebCam's cam followers. Stock followers won't stand a chance against that cam's surface hardness.
rfinegan
May 4 2022, 06:44 AM
most likely double valve springs are required too
colingreene
May 4 2022, 09:15 PM
I run this cam in a 2258 with 9:1 compression.
Its very driveable and pulls till about 5500 6k.
I did do the dual springs lifters and steel pushrods.
And I swapped from 2.0L to 1.7L rockers to have elephant foot adjusters.
I doubt it will work well with factory fuel injection but for everything else it works just fine.
swood
May 9 2022, 05:57 PM
Any interest at $275 with gear? I won't be using this one.
thanks.
S
