QUOTE(tsvo @ Apr 29 2022, 04:58 PM)
QUOTE(friethmiller @ Apr 29 2022, 05:47 PM)
You're sure it's not your fuel pump? That's a necessary buzz
That’s a good question. It is not as loud as when you turn the key to cycle the fuel pump, but it is a similar sound. I replaced the fuel pump a couple thousand miles ago. I will get under the car and listen for that. That might be why I’m having trouble finding it. I don’t think it was always this loud. Could there be a resin that it would get louder?
did you get wax cleaned out of your ears?
hearing deterioration is always a serious consideration when i consider
if it is the fuel pump - maybe its mounting bolts have worked loose. and its vibrating.
or - its deteriorating. assuming you have the fuel pump in front location.
check the filter. perhaps its dirty and fuel pump is fighting it.
I am slightly older than the car. Hearing is an increasing issue!!!!
Fuel pump is moved up front. I’ll check bolts and filter.
