Geezer914
Apr 30 2022, 04:10 AM
I noticed when I press hard on the brake pedal the clutch pedal slightly moves. Which means the floor pan is flexing. I have a spacer wedged between the master cylinder and steering rack to prevent the master cylinder from moving. Best way to reinforce the area around the pedal cluster?
Van B
Apr 30 2022, 08:25 AM
You sure the pedal box is bolted down tight with all four bolts?
BillJ
Apr 30 2022, 09:36 AM
Thats what i would check first
tygaboy
Apr 30 2022, 09:41 AM
That's not an uncommon area for rust, so check for that, too.
mgphoto
Apr 30 2022, 09:44 AM
Install Tangerine Racing master cylinder brace, I’m using it for 10+ years, I have lots of confidence when I smash the brake pedal.
