Just started driving the car after sitting for 15 years. Runs ok except when I go to shift up or down, the engine speed doesn't drop right away when I push in the clutch. It just sits there for a few seconds and will then SLOWLY drop down
Have new vacuum lines on engine and all are tight. Will check again.
Lubricated the pivot points for the accel cable at the gas pedal and the pedal thinking maybe the pedal was sticking. All good.
Adjusted the idle screw. Now at 1000 RPM when engine warm.
Clutch and accel cable are original to the car so they can't be tangled up.
When we were getting the car running again, the aux air regulator would not close, and the engine would run at almost 3000 RPM at idle. Took it off, heated it up, sprayed the daylights out of it with PB Blaster, heated some more, and spring inside finally popped loose. Checked it with power from the battery and it closed when it got hot and opened when cooled.
If this thing didn't completely close off when hot, could that be causing the engine revs to stay up in between shifts?
Could drive it the way it is, but that can't be good. What else to look at??? Would appreciate any suggestions. Thanks.
Ed
