I have some questions regarding the PCV on a 73 2.0 / Djet. Here is some background:
I'm currently using the PCV solution which is posted on this site:
Ultimately I want to install an original PCV which I have in my possession:
The part where the Oil Inlet and the PCV go attached to looks different than pictures I've seen and the valve doesn't fit. It's too large and the "box" has a tube shaped portion where the PCV should go.
Do I have the right piece? If I do how is the PCV attached?
