QUOTE(Robarabian @ May 10 2022, 10:12 PM)
I just installed a new sender in my 71. When you buy them new, there is a small pin installed to keep the float from moving up and down, mostly up. Take it out and make sure they pulled the pin out. IF it is in, the float cant move upward. You should be able to hold it upside down and hear the float move to the top, then turn it 180 and hear it move to the other end. There is a small sticker that is usually over the pin...It sounds like it is being prevented from reaching full..
Sounded like a great theory, so had to test it. With the pin in, I got just a very small bump up from empty, almost imperceptible movement.
Click to view attachment With the pin out, of course it moved full travel.
Click to view attachment Any case, as other people have said, likely something jamming the movement of the float inside the tube. Pop her open and have a look.
Dan
