QUOTE(JamesM @ May 12 2022, 10:08 AM)
QUOTE(Montreal914 @ May 12 2022, 06:32 AM)
QUOTE(JamesM @ May 11 2022, 07:03 PM)
The late 74 strap (which is a VW part number) mounted to a small stud on the rear engine bulkhead...
@JamesM Is there a part number or vehicle model and year for this?
I am looking at relocating the canister to the back in my 73. I've already procured a plastic canister for the ease of refilling.
Thanks!
I would have to do some digging to find the part number again but if you are relocating to the rear on a 73 I would probably look for the 75+ strap instead as they 1.seem to be easier to come by and 2. the late 74 mounting location requires a small stud on the rear bulkhead that i believe only exists only on the late 74 cars where as the 75 strap mounts to the battery hold down bolt.
The VW part used on the late 74 strap when used in the VW application it got welded to the chassis so there are not as many of them around as you might suspect for being a VW part. ill see if i can find the number...
just about all the 74 1.8s have the engine bay mount.
changeover was nov 20 73.
given numbers for 75s made v 74s there would be just as many engine bay straps as the other second hand or in junkyard 914s? (EDIT - ie the two types of engine bay straps).
74 version mounts canister in a good spot out of the way.
theoretically there would be thousands upon thousands of the 74 style strap fixed to u/s of bus engine bay top sheet metal and in the rear wheel well of beetles. as noted, seemed to be spot welded on. might get one out with some judicious grinder use?
the info is in on how those things get plumbed up too.
the hose hook up changed with shift to engine bay cans.
if you are interested.
it will be up in the originality section soon.
some detail is there already. in EC-A and EC-B thread.
