Remember - these hoses are routed along the inner fenderwells , down to the rockers and back up. The Rod Simpson conversion uses alot more hose in the engine bay as the water pump is on the passenger side - one of the two 3/4” hoses goes from the right lower side, under the engine towards the driver side, up to the top of the motor, and back down to the custom water inlet on the front of the motor (and jammed against the firewall with nearly inaccessible allen head bolts
:shoot2kill - that was literally a few days of hell since there was no way I was going to drop the motor on the slanted street).
Here’s the actual footageof Gates Green Stripe hose cut and purchased by me:
18’ x 1” id
21’ x 3/4” id
3’ x 3/8” id
This does not include the 1.5” id and 1.75” id hoses.
For the 1” id, I did have to put a loop in the front, and may have 2 to 3 feet left over when I have everything done, as the new routing was experimental and I had to return the 50ft rolls to the parts store asap.
For the 3/4” id, I may have 6” left over at the end, and I have used 1 foot more than a tight direct fit to the engine water outlet so I can install an inline bleeder and temporarily raise it above the expansion tank and thermostat housing if necessary.
Without the loop and extra routing, the final (taught routing, if you will) would be:
13+ to 14’ x 1” id.
19.5’ x 3/4” id.
Essentially, the Renegade setup is a straighter shot from pump to block (very short hoses coming from the same side of the motor) and a straight shot from the motor to the radiator ( which has the inlet and outlet on the same side). However those hoses are generally (not always) routed underneath the pan whereas the Rod Simpson set up has the main hoses fairly well protected by the rocker and fender wells.
I have some friends who have a highly built first gen 911 and their oil cooler hoses are routed under the pan - that car is pretty low and when I first inspected it, I cringed at how naked those hoses (and clamps) were even though they’re made from tough rubber composite. I far prefer to have 10 feet more of hoses and have them routed through the rockers - although cutting holes in the car especially whilst all bent up in the engine bay coming from the top wasn’t any fun-lol.
I have also read that centrally mounted hoses ( especially those mounted within the central tunnel ) can generate quite a bit of heat in the cabin.
