sjhenry1075
May 13 2022, 01:28 PM
In preparation for the 914 gathering in July, I'm preparing to replace my clutch and accelerator cable. I was searching YouTube for a video and found one, but in the comments someone had stated that driving without the pedal board will actually stretch the cables. Is this true? I drive without the board for extra room ( I wear a size 18 shoe). As it is I have to take off my shoes to drive. Do I need to reinstall the pedal board?
lierofox
May 13 2022, 01:34 PM
Pedal board has the stopper on it, but I imagine it's more a matter of if your clutch is adjusted such that the throwout arm can bottom out on the transmission casing before the clutch pedal hits the bulkhead without the pedal board/stopper there to prevent it, then that would slowly stretch the clutch cable.
sjhenry1075
May 13 2022, 01:45 PM
QUOTE(lierofox @ May 13 2022, 03:34 PM)
Makes sense, thank you! I'll be sure to adjust it with this in mind.
mgphoto
May 13 2022, 04:37 PM
Without the stop, the clutch tube will eventually pull though the body of the car at the firewall, over pushing the clutch pedal will cause the throw out bearing fork to strike the transmission case, this will cause the weakest point to fail the sheet metal.
76-914
May 13 2022, 07:20 PM
There should be a place to thread in a bolt on the back side of the clutch pedal. Use a nut to lock it in place once you get the desired length set.
Steve
May 13 2022, 08:28 PM
The throttle cable also requires the pedal board.
IronHillRestorations
May 14 2022, 05:42 AM
Not having a pedal board will also stress the pressure plate.
dr914@autoatlanta.com
May 14 2022, 09:29 AM
QUOTE(mgphoto @ May 13 2022, 03:37 PM)
totally agree, we have seen WAY too many clutch tubes rip loose and expensive and relatively complicated repair
brant
May 14 2022, 09:27 PM
You need to have a pedal board. Required
VaccaRabite
May 14 2022, 09:41 PM
Yup. You need that pedal board, or at least yo need to make a custom stop for both the clutch and throttle cable. But really, just use the pedal board and adjust the stops.
Zach
