redshift
Aug 3 2005, 03:45 AM
After:
Complete tuneup, all everything
90% renewal of terminations in ignition system
Removing EVERYTHING related to the interlock
Cleaning all the connections at the relay panel
Some joy.
When the car gets warm, it's idled up to about 1100, from previous 950... that told me I got the lost spark back.. one problem down. Pulls smoothly, and just runs way better.
BUT, still, on any drive, 3 to 30 minutes long, there will be a time, at least once, where I completely lose ignition.. just as if switching the key off, OR, it may feel like I switched off only HALF the ignition..
EDIT: All I have to do, is reset the key, off, and on, then pow! Off to the races... maybe once, maybe twice.
So, next thought: relay panel, injection brain.
Anyone want to venture a wild stab? I cannot make it happen while testing. heh.
M
redshift
Aug 3 2005, 05:51 AM
Quite impossible! I wish!
I feel terrible. I got tangled in the wiring, and missed grasshopper coming thru town..
... while I was pulled over off HWY 80, doing some probing with the meter... sweating, and cursing.
Swapping relays around a bunch hasn't moved the problem, I think I will strip the panel down today, and work at that for a bit.
M
ArtechnikA
Aug 3 2005, 06:06 AM
stock ignition, or aftermarket CDI?
when you lose power, does the tach still register, or does it instantly drop to zero?
redshift
Aug 3 2005, 06:14 AM
I never thought about it! Tach registers.
Stock ignition.
Hmm..
M
redshift
Aug 3 2005, 06:17 AM
Rich, it's the brain, isn't it?
M
redshift
Aug 3 2005, 06:29 AM
Sounds like good advice.
I wish I could make it fail while testing.
M
ChrisFoley
Aug 3 2005, 06:36 AM
I've seen similar intermittent problems occur from bad FI trigger points. The car would unexpectedly lose power/shut down, then be fine for a while after restarting. Owner wanted me to replace the fuel pump. New trigger points completely eliminated the problem.
redshift
Aug 3 2005, 06:45 AM
I will check them out, not brand new, but cleaned up, and uhh.. around 17k on them? Maybe 20.
As frustrating as the problem can be, it's very interesting too.
M
