Decel valve, side (suck) to under plenum, nose to (?)
I bumped something!
M
bd1308
Aug 3 2005, 12:26 PM
pelican has a hose diagram.
tech section
redshift
Aug 3 2005, 12:29 PM
Yes, it's very helpful, it's like a tit without a nipple.
DAVE!!
M
bd1308
Aug 3 2005, 12:30 PM
i took mine out a long time ago.
just plugged up the offending holes.
redshift
Aug 3 2005, 12:50 PM
The suck side is under the plenum, the nose is plugged into the airbox..
I hope that is right.
Ok, barring new developments, my car is a low yield nuke, and pulls like a tractor to redline, and it hasn't cut out on me in 20 minutes of driving.
But, I went to the bank, in 2 minutes... hot start now..
ben1440
Aug 3 2005, 12:56 PM
What is the decel valve for exactly. I have mine hooked up on my 1.8 l-jet. would there be a benefit to plugging it on the air box and on the other side? I also have the nose plugged on the airbox where it would go to an egr valve which i do not have in my car.
redshift
Aug 3 2005, 04:13 PM
YAY!!!!!!!
Dave_Darling
Aug 4 2005, 12:24 AM
The DV is just a valve. When the little line sees a high enough vacuum, it unblocks the air passage between the two large lines. So the large ones can go either way around--one connects to the manifold, one to the air cleaner.
On a 1.8, that last one would connect to the rubber "boot" between the air flow meter and the throttle valve.
--DD
redshift
Aug 4 2005, 12:27 AM
Thanks Dave.
(I mean for turning around in your avatar)
M
Bleyseng
Aug 4 2005, 07:59 AM
its a vacuum leak for emissions so that are hard decel the engine has a bit more air. rip it out.........plug the hoses.
redshift
Aug 4 2005, 10:04 AM
No! It's too close to the MPS, and I am not having parts thinking that they are next, and just giving up.
M
bd1308
Aug 4 2005, 10:31 AM
QUOTE (Bleyseng @ Aug 4 2005, 07:59 AM)
i'm telling ya miles, rip that out man.
ClayPerrine
Aug 4 2005, 11:24 AM
The 2.4 doesn't have one (never did) and the 1.8 decel valve was removed and replaced with an idle up solenoid for the AC (which, btw, is not big enough).
