Last week, @Dion sent me a note asking how my car was doing, to which I responded all is well...no major issues since she returned from in-op to driver status last year.
Today, I went to wash my car and got a bit of a scare while it was idling in my garage...I saw a pool a fuel quickly forming under the car!
Good thing I was out of the car and close by where the leak was quickly noticed. I almost slipped on the quickly forming lake of fuel forming under the car as I was sprinting for the ignition switch!
First thing I noticed after shutting the car off (other than the stench now emanating from my trousers!) was that the fuel pressure at the regulator was zero...OK, so I have a leak in the fuel line between the stainless feed and the regulator.
Didn't take long to find that my 1 year old plastic fuel filter had ruptured!
So I'm not sure if this is a question, or a public service announcement...
Last year, when I re-assembled my car (2.7L six conversion with dual webers), I went with a low pressure Delphi FD0037 fuel pump. Before I disassembled my car for the rebuild, I was running the OEM (hi-pressure fuel injection) fuel pump with dual regulators on the discharge (and maintained the recirc to the tank)...not ideal, but it worked for about 6-7 years with no issues. Just to clarify, I did my 6 conversion several years before I opted for rust repair and a GT body style conversion.
To simplify my fuel feed, I went with a Delphi lo-pressure pump, I did notice what I thought was a high speed "hesitation" and assumed that the pump was undersized...I knew I was only getting about 2-1/2 psi to the regulator ahead of the carbs at idle. (Adjusting the regulator and I could never get anything more than 2-1/2 psi.) That Delphi pump is also rated at 4 GPH which should[i] be sufficient, excluding head pressure loss.
Late last summer, due to what I suspected was a high speed fuel starvation, I upgraded to a higher volume lo-pressure pump...the Walbro GSL395.
When I installed the Walbro pump, I did measure a fuel supply pressure of between 15-18 psi before the reducer (dialed down to 3 psi for the carbs).
I've been running the car since last summer with this set-up until today.
I should mention that I have a WIX 33003 (3/8" feed/discharge) fuel filter on the suction side of the fuel pump (under the steering rack) as well as the same filter installed ahead of the pressure regulator at the engine bay.
Essentially, the filter ahead of the regulator is seeing an inlet pressure of 15-18 psi (measured)...I didn't think, at the time, that this would be a big deal for the plastic filter. (I thought wrong!)
I cannot find a (max) pressure rating for the WIX 33003 fuel filter, although there are a couple of websites (not WIX) that advertise a max pressure diff of 75 psi...color me dubious!
As mentioned previously, I do have a single feed SS hard line from the front of the car into the engine bay.
I use small lengths of Gates 3/8" fuel hose (50 psi rating) for the rest of my fuel feed to the carbs.
Obviously, this failure of the WIX 33003 fuel filter has me a little shook.
I do have a few options.
1) Install a recirc system to reduce "dead-head" pressure at the regulator.
2) Investigate finding a "lower" pressure supply pump.
3) Eliminate the fuel filter ahead of the regulator (since it is secondary to the filter ahead of the pump)
4) Replace the plastic WIX filter with a metal encased fuel filter ahead of the regulator
5) Other suggestions...
The regulator I'm using is the Aeromotive 13222...20 psi max inlet adjustable to a range of 1 - 5.5 psi. In theory, I shouldn't have to run a recirc...this regulator is designed to run without.
My question would be to others running 6 conversions with carbs (or even 4's with carbs)...what are you guys running for a fuel supply system?
I like the plastic fuel filters just for the visual confirmation of fuel system cleanliness. Now I'm not so sure of this convenience.
Has anyone encountered a plastic fuel filter failure like this?
I've seen far too many photos of 914's with torched engine bays...or worse...don't want to be another statistic.
This might be a good time to take another look at engine bay fire suppression systems.
Attached is a copy of the Walbro pump pump pressure curve...as mentioned, I have measured feed pressure between 15-18 psi at the engine bay ahead of the regulator.
Also included is a photo of where/how the fuel filter failed. (I was going to assume "Made in China" but it's stamped "Russian Federation". Go figure!)
Help/ideas would be greatly appreciated!
Thanks in advance!
Rob
