what kind of signal do you need?
1 per event? or do you need more resolution?
/4 or /6?
if /6 and you need a 60-1 wheel,
Clewett Engineeringif /6 and 36-1 wheel do a search for Dr. Evil's post on his megaspark (EDIS based) ignition wheel
if /4, do a search for Dave Hunt's install, his came out better than mine
(2 wheels shown for comparison)
I am not using the crank trigger setup now, instead my triggering come from the distributor (locked mechanical, my ECU controls the spark)
if you need only 1 signal per event and a /4, Ben M. and Mark Henery mounted the magnet for the hall effect sensor on the fan
Hopefully they will chime in and post pictures.
