QUOTE(sumcar71 @ May 30 2022, 08:05 AM)
I have a 1971 914 with fuel injection and points and I’m looking to install Pertronix electronic ignition. Do have to modify primary wiring to ensure 12 volts at positive side of the coil? Will the factory tachometer still work?
Just use the correct Pertronix coil for the module you buy ,I use Igniter II and Clewitt Eng plug leads for my "6",been great for some time ...no issues ,I don't use the Pertronix coil and I have Permatune CDI so use their matching transformer coil to best effect.
Your stock tacho should be fine,you will need to wire the setup as per their instructions however.
Click to view attachmentClick to view attachmentShown is the 3 pin CDI and the other for T4 motor.
If unsure you can visit their site and download the fitment manual before you order your unit.
