QUOTE(bdstone914 @ Jun 4 2022, 05:41 AM)
Drain the oil from the transmission. Remove the two 13mm nuts that hold the assembly to the transmission then drive out the roll pin to remove the shaft.
Actually what I think Bruce intended to say is "the roll pin from the top of the shaft".
There is a roll pin also holding the shift ball to the bottom of the shaft but since the one
at the top, (#16), is always bathed in oil it is normally easier to remove.
